2 extensions, one voice mailbox
aapexisinc
Is there a way to set up CUE so that two extensions go to the same voice mailbox (not general delivery, but a user mailbox)?
pro4ianyc
do you need to see MWI on both extensions?  if not, if you have direct to voicemail prefix setup, you can always configure the 2nd extension's forward no answer or forward busy to the first extension's direct to voicemail ext..
