Additional BRI Interface
celiorodrigues
Hello all,
I had an UC520 with one interface BRI configured, with installed a new isdn line and connected it to the second BRI interface, we are receiving 4 calls that shows us that the bri is working, but we are unable to make more than two simultaneous call to outside the organization, what i need to change in order to be able to use the additional bri interface to perform outside calls.
kind regards,
Celio Rodrigues
David Trad
Hi Celio.
Firstly I would look at the TE configuration, just make sure it is in-line with what the carrier has provided you on your ISDN line, then check and make sure that the Layer-1 Is made permanently active by the carrier.
Can you do a "debug isdn q931" and capture what happens when you go to make the 3rd call, don't forget to do a "term mon" to capture the debug.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
