05-01-2012 11:06 PM - edited 03-21-2019 05:44 AM
I have some issue regarding the fac configuration in UC560.I have configured fac or international numbers.So when i dial international number, i am getting promt to dial pin.Once i put pin, call is just getting looped inside.Its not going out side.Below is my configuration
*********Fac-service**********
application
service clid_authen_collect
param uid-len 3
param pin-len 3
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
username 101 password 101
username 101 autocommand exit
***********COR-list********
dial-peer cor list call-ISD
member ISD
dial-peer cor list ISD-CALLS
member INTERCOMM
member LOCAL
member MOBILE
member NATIONAL
member ISD
************Dial -Peers8*************
dial-peer voice 40 pots
trunkgroup ALL_FXO
corlist incoming call-ISD
corlist outgoing call-ISD
description ------ Outgoing ISD Calls(FXO) ------
preference 5
destination-pattern 900T
incoming called-number 900.T
forward-digits all
no sip-register
dial-peer voice 2500 voip
description International Calls
destination-pattern 900.T
session target ipv4:192.168.120.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
*************Ephone-dn**********
ephone-dn 22 dual-line
number 202 no-reg primary
label 202
description Meeting Room 2
name Meeting Room
corlist incoming ISD-CALLS
huntstop channel
When i debug ,could see this :
%CALL_CONTROL-6-CALL_LOOP: The incoming call has a global identifier already present in the list of currently handled calls. It is being refused.
Please help me.
Solved! Go to Solution.
05-02-2012 06:44 AM
Hello Ameen,
I would like you to try one thing. Remove the COR list statement:
from "dial-peer voice 40 pots". Then test the call again.
Thank you,
Darren
05-02-2012 06:44 AM
Hello Ameen,
Thank you,
Darren
