Call Waiting CID not working - SPA122 - SPA232D
ciscojoe837
Is there a fix for the Call Waiting Caller ID for these units?  When a second call comes in, you can hear the Call Waiting Beep, but the Call Waiting Caller ID does not show even though it is set to Yes in the Supplementary Services.  I tested both with the latest firmware and even downgraded firmwares just to see if it would work - it doesn't.  Using firmware 1.3.5 for both units.
Dan Lukes
If I would say true, I'm not sure the CWCID is supported on SPA232D. It may be supported on wired/analog line only.
You may consider to turn on syslog&debug messages and catch them. It may reveal valuable information related the issue you mentioned.
