07-01-2009 05:19 PM - edited 03-21-2019 01:15 AM
Hi All,
System UC520
I can call the the analogue extension the cordless phone is on but i can NOT Transfer to it. Is there anything i should enable to allow transfer to analogue port?
below is the running config for that port.
voice-port 0/0/2
cptone AU
timeouts ringing infinity
station-id name FXS Port
station-id number 194
caller-id enable
Thanks in advance
07-27-2009 06:37 AM
jpotamitis1,
In UC500/CME you should be able to transfer amongst SCCP endpoints without issue and by default. The issue comes in with transfering to POTS or Analog ports, and this is by design for security purposes. To enable the transfer you need to add some transfer patterns to the telephony service like this:
telephony-service
transfer-pattern .T
Check out the SRND guide for CUCME on this topic at: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/clproc.html#wp1068396
And also the reference guide for the specifics on the command options as you might not want to allow a call to be transfered to "anywhere". The guide is here: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_t1ht.html#wp1018955
Have a great day!
-Ben
08-18-2009 05:03 PM
I moved this to the UC500 section of the Small Business Support Community so others could benefit from the discussion.
Laura Douglas
Cisco Collaboration Community Manager
08-19-2009 07:58 AM
You should be able to make this transfer work. Can you post your config?
