cca xml export for SIP Trunk service providers, request or schema.
ADAM CRISP
Level 4
Level 4
Please can I have the complete xml schema for SIP trunks so I can create a proper template?
Exporting from CCA 3.2.2 gives me an incomplete and sometimes inaccurate xml file
example: toll fraud protection  - I would like to add this in to the template - how
SIP registration: If I set this to 120 on CCA and export - the exported template remains as 3600
thanks
Adam
ADAM CRISP
Level 4
Level 4
Cisco - anybody there?
trgood
Hi Adam,
Are you saying when you try to export your SIP trunk settings via CCA that your settings are incorrect in the xml file?  If so, I recommend opening a case to troubleshoot the issue as it sounds like a bug to me.
-Trent Good ** Please rate useful posts! **
