Cisco 514G Template
bruce
Hello-
I have configured the programmable soft keys on my SPA504/514 phones using a browser connection to the phone but need to make it more permanent.
I am using a softswitch that has templates for many phones, including the Cisco SPA504G/514G.  I would like to make some additions to the template in order to configure programmable softkeys and then assigning them to various positions within the context sensitive buttons.
Here is what I have added using the browser:
fnc=blf+sd+cp;sub=park+*5900@<softswitch-url>;ext=park+*5900@<softswitch-url>;vid=1;nme=park
fnc=blf+sd+cp;sub=park+*5901@<softswitch-url>;ext=park+*5901@<softswitch-url>;vid=1;nme=unpark
Connected Key List:
hold|1;endcall|2;conf|3;xfer|4;psk1|5;toggle;bxfer;confLx;xferLx;park;phold;flash
Offhook Key List
redial|1;dir|2;cfwd|3;dnd|4;psk2|5;pickup|7;gpickup|8;starcode|11;alpha|12
How do I add this to the XML template for the phone?
Thanks in advance for your help!
5 Replies 5
Philip D'Ath
Here is an example for button 4:
<Extension_4_ group="Phone/Line_Key_4">Disabled</Extension_4_>
<Line_Enable_4_ group="Ext_4/General">No</Line_Enable_4_>
<Extended_Function_4_ group="Phone/Line_Key_4">fnc=sd;ext=*88@$PROXY;nme=Group Pi
ckup</Extended_Function_4_>
<Programmable_Softkey_Enable group="Phone/Programmable_Softkeys">Yes</Programmable
_Softkey_Enable>
<Connected_Key_List group="Phone/Programmable_Softkeys">hold|1;endcall|2;conf|3;xfer|4;psk1|5;toggle;bxfer;confLx;xferLx;park;phold;flash</Connected_Key_List>
Thanks - I'll give it a try!
I used your information as a guide and am almost there.  One thing that is holding me back is the following.  In my template, I have the following line:
<Programmable_Softkey_Enable group="Phone/Programmable_Softkeys">Yes</Programmable_Softkey_Enable>
However, the config on the phone always says no:
<Programmable_Softkey_Enable group="Phone/Programmable_Softkeys">No</Programmable_Softkey_Enable>
If I set it to yes from the web gui, everything works fine but I want it to be set to yes from the template. Is there something else I need to do?
I started over and now it works; go figure.  Thanks for the help!
Philip D'Ath
