Cisco spa 508g hold by headset button
vinta.org
Hello!
There is headset button and if you press it call will be answered if press it again call will be droped. So we need program this button not to hung up when call received but to hold call by this key. Or make this button only for answer with headset. How to do it ?
Firmware version 7.4.9a
atcomputing
Nothing is wrong when you use the button for the right purpose (when a headphone is connected)!
Dan Miley
Level 3
Level 3
The document for programming the soft keys (under the display) are here
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa500_admin.pdf
page 300
The handset key is not programmable.
Maybe there is solution how to disable call drop after second button press?
