Cisco SPA 525G2 IP Phone
vangersh1
Hi all,
I just got myself a Cisco SPA 525G2 -5Line ip phone to configure which is totally not working.
I'm configuring it in SIP mode with the a static IP address.
The following have all been configured and rechecked :
STUN Server:
SIP Parameters
SIP Port number
Proxy:
Subscriber Information
When all these configuration are saved .. I still get the following error message :
Registration State:    Failed - Not Reachable
Can I kindly get help from or tips in configuring this? Thanks
Sean
Jaime Valencia
You probably want to move this to the SMB community
java
if this helps, please rate
Moved it over there. Thanks
