copying setting parameters ATA SPA112
nicolunardi1
Hi, I would like to export settings of my ATA, but I don't find such a function on the menu. Should I have this log, I could send the data to my provider, as I am not receiving phone calls (but I can call). Wizard inside VOICE/SIP cannot be copied/pasted indeed.
Thanks.
Firmware Version: 1.4.1 (002) Oct 26 2015
7 Replies 7
Jaime Valencia
SPA endpoints are supported in the SMB community, might want to move your thread over there.
java
if this helps, please rate
Gracias Jaime, esto forum para mi es realmente un labirinto.
If you prefer Spanish you should consider to ask in Soporte a empresas pequeñas instead.
Read Retrieving SPA112 & SPA122 Configuration URL
Most of time either NAT/firewall issue or you SPA112 is not properly registered to provider (no attempt to register at all, or registration rejected by provider).
Hi Dan, with my spanish answer to jaime I just wanted to thank him warmly.
I originally use to receive phone calls, but, suddenly it doesn't work anymore. I change no settings.
I followed this link of yours  SPA IP Phone: Extracting Configuration with spacfg.xml
and it works.
I made also a big mistake in the thread you sugested me, sorry. I clicked "report" and now it is not possible to "unreport". This is the result [code]Bad token. You seem to have followed an invalid link[/code]
Glad to hear you saved configuration successfully.
According "unreport" - just reload page and try again. I tried it, it should work.
Works. thanks again and sorry for the inconvenience
No problem. You may consider to rate comments according your wishes - it may help others ti discover valuable answers.
