Hello Mr. Friese,
According to the information found the maximum voice calls depends of the device.
Let me share with you the chart found:
Conference Bridge Type | Description |
Cisco Conference Bridge Hardware (WS-6608-T1 or WS-6608-E1) | This type supports the Cisco Catalyst 4000 and 6000 Voice Gateway Modules and the following number of conference sessions. Cisco Catalyst 6000 •G.711 or G.729a conference—32 participants per port; six participants maximum per conference; 256 total participants per module; 10 bridges with three participants •GSM—24 participants per port; six participants maximum per conference; 192 total participants per module Cisco Catalyst 4000 •G.711 conference only—24 conference participants; maximum of four conferences with six participants each |
Cisco Conference Bridge Software | Software conference devices support G.711 codecs by default. The maximum number of audio streams for this type equals 128. With 128 streams, a software conference media resource can handle 128 users in a single conference, or the software conference media resource can handle up to 42 conferencing resources with three users per conference. Caution If the Cisco IP Voice Media Streaming Application service runs on the same server as the Cisco CallManager service, a software conference should not exceed the maximum limit of 48 participants.
Cisco IOS Conferencing and Transcoding for Voice Gateway Routers | •Uses the NM-HDV or NM-HDV-FARM network modules. •G.711 a/mu-law, G.729, G.729a, G.729b, and G.729ab participants joined in a single conference •Up to six parties joined in a single conference call Cisco Unified Communications Manager assigns conference resources to calls on a dynamic basis. In a Cisco Unified Communications Manager network that includes both Cisco IOS Conferencing and Cisco IOS Enhanced Conferencing, set the Cisco CallManager service parameters, Maximum Ad hoc Conference and the Maximum MeetMe Conference Unicast, to six conference participants. For more information about Cisco IOS Conferencing and Transcoding for Voice Gateway Routers, see the IOS documentation that you received with this product. |
Cisco IOS Enhanced Conferencing and Transcoding for Voice Gateway Routers | •Uses the onboard Cisco Packet Voice/Fax Digital Signal Processor Modules (PVDM2) on the Cisco 2800 and 3800 series voice gateway routers or uses the NM-HD or NM-HDV2 network modules. •G.711 a-law/mu-law, G.729, G.729a, G.729b, G.729ab, GSM FR, and GSM EFR participants joined in a single conference •Up to eight parties joined in a single call. Tip In Cisco Unified Communications Manager Administration, ensure that you enter the same conference bridge name that exists in the gateway Command Line Interface. Cisco Unified Communications Manager assigns conference resources to calls on a dynamic basis. In a Cisco Unified Communications Manager network that includes both Cisco IOS Conferencing and Cisco IOS Enhanced Conferencing, set the Cisco CallManager service parameters, Maximum Ad hoc Conference and the Maximum MeetMe Conference Unicast, to six conference participants. For more information about Cisco IOS Enhanced Conferencing and Transcoding for Voice Gateway Routers, see the IOS documentation that you received with this product. |
Cisco Video Conference Bridge (IPVC-35xx) | This conference bridge type specifies a dual multimedia bridge that provides video conferencing. The Cisco Video Conference Bridge provides audio and video conferencing functions for Cisco IP video phones, H.323 endpoints, and audio-only Cisco Unified IP Phones. |
Cisco Conference Bridge (WS-SVC-CMM) | This conference bridge type supports the Cisco Catalyst 6500 series and Cisco 7600 series Communication Media Module (CMM). This conference bridge type supports up to eight parties per conference and up to 64 conferences per port adapter. This conference bridge type supports the following codecs: G.711 mu-law, G.711 a-law, G.729 annex A and annex B, and G.723.1. This conference bridge type supports ad hoc conferencing. |
Thank you
Diego Rodriguez
Cisco network engineer
If this answer was satisfactory for you, please mark the question as Answered.
Hello Mr. Friese,
Hello Mr. Friese,
Thank you
Diego Rodriguez
Hello Mr. Friese,
Thank you
Diego Rodriguez
Hello Mr. Friese,
Thank you
Diego Rodriguez
