12-08-2015 04:51 AM - edited 03-21-2019 10:30 AM
Is there a way to deregister a SPA302D handset from SPA232D base administration interface?
The SPA302D handset was broken and I cannot unregister it from the handset menu.
Solved! Go to Solution.
12-12-2015 09:11 AM
I'm not in my test lab with SPA232D now, so my advice is based on just Administrators guide.
It mention you can deregister other handsets from the one already registered. SO use other registered handset to deregister all others, including the one broken (search for text "Deregister others" in Administrators Guide).
And as last resort, reset to factory default should deregister all handsets.
12-12-2015 09:11 AM
