Dialing Analog ports/phone
bjames
Level 5
Level 5
Sorry,
Kind of a dumb question, but I cannot seem to dial a phone conencted to an analog port... The ports have 301, 302, etc. and the phones were setup with locals 210, 211, etc. I tired dialing both the 210 and 201 with a analog phone plugged into the port but couldn't make it ring? I was able to dial-out on it just fine...
What am I missing?
7.1.3
Steven DiStefano
User mode phones plugged into FXS ports get ephone extension ranges usually, whete fax and common area usually get 3XX.
Make sure you plugged in fxs, not fxo...maybe...
All the FXO's are in use (with in-bound analog lines)
How do the locals map the the FXS?
In cca there is the config screens for analog ports
