04-04-2013 04:01 AM - edited 03-21-2019 07:12 AM
Dear,
Is there a solution to get Call Detail Record from cisco spa 50xg like a "provisioning" setting ?
What i will do, is to have the call history from each phone, and send it to a crm.
I have cdr from ippbx but not like a will.
Another question, is possible to a cisco spa to send his status (like subscribe) to a server like "provisioning" ?
If yes, i can develop a cti integration who is not operating system dependant.
Solved! Go to Solution.
04-05-2013 05:16 PM
Maybe, a feature request to cisco.. send call log to a server from the phone.
I disagree. User's device is under physical control of the (untrusted) user. There is problem with authenticity and reliability of anything that come from such source. On oposite side, the PBX have all necesarry informations already (and no problem with security). The ultimate source of the log of calls should be PBX, not the user's device.
All at all, as I mentioned in my comment, there is no usable CTI support in SPA* devices in SIP mode. I assume the CIsco doesn't want to ruin their bussiness with Call Manager or so ...
04-05-2013 01:10 AM
As far as I know, nothing better than http://.../calllog.htm
Well, you can catch syslog/debug messages and analyze them for the call data.
I'm not sure what you mean "status of cisco spa"
04-05-2013 07:05 AM
Dear Dan,
For call log, its bad new for me :(
For phone status (idle, on call, ..caller id to search in a crm) too bad new.
I have do a clicktocall in sugarcrm who send ciscoipphoneexecute dial:numberclicked but this is one way
To here, i have resolved :
Extention mobility : work well
ClickToCall : work well
cisco spa500s : error 481 (call leg..) if subscripted phone boot after the phone with spa500s. I dont Knowl if i must open a bug in cisco or at draytek.
Full cti intégration need some more feature for ours ip pbx or cisco Spa phone
04-05-2013 05:16 PM
