Having issues with SPA9000 + SPA400 + SPA504G x 2
Aldernadie1
BETA version of the SPA9000 Voice System Setup Wizard version 2.1.1.2.
SPA9000 + SPA400 plus 2 x SPA504g. We have ran the wizard and all connected. Only one of my two IP phone lines is connected to ISP. Only one of them is detectable through the wizard. Also, I can’t get voicemail working when using the wizard.
it would not allow to register through the wizard a second VOIP line, only one as the other options are not valid for registering an addition ISP voip line. This limits the ability to run two separate Cisco phones on different lines.
Should we be registering the main line in the wizard as the SPA 400 and then trying to configure both voip lines through the SPA 400?
0 Replies 0
