Help with ACL
ralmendares
Buenas tardes, tengo un problema tengo una central UC540 en la matriz, en una sucursal tengo un router SA520W y en otra sucursal un router SR520, he logrado que haya comunicacion(voice vlan) entre todos los locales, pero no logro acceder a la red de datos desde la sucursal A a la sucursal C
Sucursal A<=====>Matriz B<=====>Sucursal C
(SR520)                   (UC540)              (SA520W)
192.168.75.0            192.168.10.0         192.168.20.0
              Sucursal A<==X==>Sucursal C
A continuacion pongo la configuracion de las acl que tengo en la UC540, no se si me falta alguna:
ip nat inside source list 180 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip access-list extended exclude-vpn-statics
permit tcp any eq 1723 any
permit gre any any
permit ipinip any any
logging esm config
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 11.1.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.10.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 2 permit 11.1.1.0 0.0.0.255
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 3 remark SDM_ACL Category=2
access-list 3 permit 192.168.10.0 0.0.0.255
access-list 3 permit 10.1.1.0 0.0.0.255
access-list 3 permit 11.1.1.0 0.0.0.255
access-list 3 permit 10.1.10.0 0.0.0.3
access-list 4 remark SDM_ACL Category=2
access-list 4 permit 192.168.10.0 0.0.0.255
access-list 4 permit 10.1.1.0 0.0.0.255
access-list 4 permit 11.1.1.0 0.0.0.255
access-list 4 permit 10.1.10.0 0.0.0.3
access-list 1723 permit 192.168.10.1
access-list 100 remark auto generated by SDM firewall configuration##NO_ACES_4##
access-list 100 remark SDM_ACL Category=1
access-list 100 permit udp any host 192.168.10.1 eq non500-isakmp
access-list 100 permit udp any host 192.168.10.1 eq isakmp
access-list 100 permit esp any host 192.168.10.1
access-list 100 permit ahp any host 192.168.10.1
access-list 100 deny   ip 10.1.1.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_4##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit udp any host 10.1.1.1 eq non500-isakmp
access-list 101 permit udp any host 10.1.1.1 eq isakmp
access-list 101 permit esp any host 10.1.1.1
access-list 101 permit ahp any host 10.1.1.1
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_14##
access-list 102 remark SDM_ACL Category=1
access-list 102 permit udp any any eq non500-isakmp
access-list 102 permit udp any any eq isakmp
access-list 102 permit esp any any
access-list 102 permit ahp any any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip 192.168.10.0 0.0.0.255 any
access-list 102 permit udp any eq bootps any eq bootpc
access-list 102 permit udp host 200.124.247.202 eq domain any
access-list 102 permit udp host 200.124.247.205 eq domain any
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any unreachable
access-list 102 deny   ip 10.0.0.0 0.255.255.255 any
access-list 102 deny   ip 172.16.0.0 0.15.255.255 any
access-list 102 deny   ip 192.168.0.0 0.0.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip any any log
access-list 103 remark SDM_ACL Category=4
access-list 103 permit ip 192.168.10.0 0.0.0.255 any
access-list 103 permit ip 10.1.1.0 0.0.0.255 any
access-list 103 permit ip 10.1.10.0 0.0.0.255 any
access-list 103 permit ip 192.168.20.0 0.0.0.255 any
access-list 103 permit ip 192.168.75.0 0.0.0.255 any
access-list 150 remark SDM_ACL Category=16
access-list 150 permit ip 10.1.1.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 150 permit ip 10.1.10.0 0.0.0.3 192.168.20.0 0.0.0.255
access-list 150 permit ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 180 deny   ip 10.1.1.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 180 deny   ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
access-list 180 deny   ip 10.1.10.0 0.0.0.3 192.168.20.0 0.0.0.255
access-list 180 permit ip 192.168.10.0 0.0.0.255 any
Gracias
10 Replies 10
ralmendares
Good afternoon, I have a problem I have a UC540 in the central matrix, I have a router branch and another branch SA520W a SR520 router, I managed to have communications (voice vlan) among all sites, but I can not access the network data from the branch to the branch C
Then place the ACL settings I have on the UC540, I do not know if missing:
permit gre any any
logging esm config
Thanks.
Podrías adjuntar  los show running-config de los tres router.
por favor.
Saludos
el show running del router SR520:
Building configuration...
Current configuration : 8259 bytes
version 12.4
no service pad
hostname SR520
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$JF9J$7qq8amfNhIs85j.MKsUJ4.
no aaa new-model
crypto pki trustpoint TP-self-signed-4089235246
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4089235246
revocation-check none
rsakeypair TP-self-signed-4089235246
crypto pki certificate chain TP-self-signed-4089235246
certificate self-signed 02
  3082023D 308201A6 A0030201 02020102 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303839 32333532 3436301E 170D3131 31313033 30313136
  31395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30383932
  33353234 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C6BB 9B7A45AF 7550E6FD 13F81CC4 E3B01A84 9CD76A7A D37C70DF 1AF525AB
  9EFE301D D82A6924 84039664 70C65A88 879134C8 C9E36445 6F8DD405 9979355F
  FC485B8B 62BABD66 E19FED29 705983E1 329135E6 CC23982F 076DBD91 CFA344D0
  BE357D39 C09BE031 16FBE391 FD33FA50 98478463 CD573799 843C4AB1 2E698A32
  51890203 010001A3 65306330 0F060355 1D130101 FF040530 030101FF 30100603
  551D1104 09300782 05535235 3230301F 0603551D 23041830 1680143D A29C8AF2
  CA2446E2 98C87317 C96DB2CB CB581330 1D060355 1D0E0416 04143DA2 9C8AF2CA
  2446E298 C87317C9 6DB2CBCB 5813300D 06092A86 4886F70D 01010405 00038181
  00B781EE 59C69397 9CAF3CCE BCFB0022 292A5188 C4E02D2B 688BFC67 F65F8970
  57586A72 7DF77164 35C25BAF 899F4BAF F22C6161 D5C1F926 BA60D94F 41DAF8F2
  59F5CDAD AF2339BB 3CDA25E5 5E70526F 9B5F3B83 5F4CF80E B533579F 15DA3923
  F6E4AF60 CFAF6C82 AF29A2A9 FA09B4E8 C4100A30 DC1BA25C BFEBCDB4 8F01C556 8D
      quit
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.75.1 192.168.75.10
ip dhcp pool inside
   import all
   network 192.168.75.0 255.255.255.0
   default-router 192.168.75.1
   option 150 ip 10.1.1.1
ip cef
ip port-map user-ezvpn-remote port udp 10000
no ipv6 cef
password encryption aes
username cisco privilege 15 secret 5 $1$A/tV$3ejNcgbAogFIHczj3Fslv1
crypto ipsec client ezvpn EZVPN_REMOTE_CONNECTION_1
connect auto
group EZVPN_GROUP_1 key ricardo2009
mode network-extension
peer xxx.xxx.xxx.xxx
virtual-interface 1
username sr520 password xxxxxxx
xauth userid mode local
archive
log config
  hidekeys
class-map type inspect match-any SDM_AH
match access-group name SDM_AH
class-map type inspect match-any SDM-Voice-permit
match protocol sip
class-map type inspect match-any SDM_ESP
match access-group name SDM_ESP
class-map type inspect match-any SDM_EASY_VPN_REMOTE_TRAFFIC
match protocol isakmp
match protocol ipsec-msft
match class-map SDM_AH
match class-map SDM_ESP
match protocol user-ezvpn-remote
class-map type inspect match-all SDM_EASY_VPN_REMOTE_PT
match class-map SDM_EASY_VPN_REMOTE_TRAFFIC
match access-group 101
class-map type inspect match-any Easy_VPN_Remote_VT
match access-group 102
class-map type inspect match-any sdm-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any sdm-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all sdm-invalid-src
match access-group 100
class-map type inspect match-all dhcp_out_self
match access-group name dhcp-resp-permit
class-map type inspect match-all dhcp_self_out
match access-group name dhcp-req-permit
class-map type inspect match-all sdm-protocol-http
match protocol http
policy-map type inspect sdm-permit-icmpreply
class type inspect dhcp_self_out
  pass
class type inspect sdm-cls-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-permit_VT
class type inspect Easy_VPN_Remote_VT
  pass
class class-default
  drop
policy-map type inspect sdm-inspect
class type inspect sdm-invalid-src
  drop log
class type inspect sdm-cls-insp-traffic
  inspect
class type inspect sdm-protocol-http
  inspect
class type inspect SDM-Voice-permit
  pass
class class-default
  pass
policy-map type inspect sdm-inspect-voip-in
  pass
class class-default
  drop
class type inspect SDM_EASY_VPN_REMOTE_PT
  pass
class type inspect dhcp_out_self
  pass
class class-default
  drop
zone security out-zone
zone security in-zone
zone security ezvpn-zone
zone-pair security sdm-zp-self-out source self destination out-zone
service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
service-policy type inspect sdm-inspect
zone-pair security sdm-zp-out-in source out-zone destination in-zone
service-policy type inspect sdm-inspect-voip-in
zone-pair security sdm-zp-in-ezvpn1 source in-zone destination ezvpn-zone
service-policy type inspect sdm-permit_VT
zone-pair security sdm-zp-out-ezpn1 source out-zone destination ezvpn-zone
zone-pair security sdm-zp-ezvpn-out1 source ezvpn-zone destination out-zone
zone-pair security sdm-zp-ezvpn-in1 source ezvpn-zone destination in-zone
switchport access vlan 75
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$
ip address dhcp
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface Virtual-Template1 type tunnel
no ip address
zone-member security ezvpn-zone
tunnel mode ipsec ipv4
interface Vlan1
no ip address
shutdown
interface Vlan75
description $FW_INSIDE$
ip address 192.168.75.1 255.255.255.0
ip nat inside
zone-member security in-zone
crypto ipsec client ezvpn EZVPN_REMOTE_CONNECTION_1 inside
ip forward-protocol nd
ip route 192.168.10.0 255.255.255.0 Vlan75
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 110 interface FastEthernet4 overload
ip access-list extended SDM_AH
permit ahp any any
ip access-list extended SDM_ESP
permit esp any any
ip access-list extended dhcp-req-permit
permit udp any eq bootpc any eq bootps
ip access-list extended dhcp-resp-permit
access-list 1 permit 192.168.75.0 0.0.0.255
access-list 100 remark SDM_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 101 remark SDM_ACL Category=128
access-list 101 permit ip host 200.124.246.121 any
access-list 102 permit ip any any
access-list 110 remark SDM_ACL
access-list 110 deny   ip 192.168.75.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 110 deny   ip 192.168.75.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 110 permit ip 192.168.75.0 0.0.0.255 any
control-plane
banner login ^CCSR520 Base Config - MFG 1.0 ^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
y el show running del sa520w no se como sacarlo, ya que todo lo he configurado via la interfaz web
Lo que sucede es que el router en la sucural a no sabe como llegar a la red de la sucursal c
Podrias aplicar este comando en la router de la sucursal A
ip route 192.168.20.0 255.255.255.0 Vlan75
por favor calificarme si mi respuesta te ayudo,
Saludos
Hola Jorge ya intente con el comando ip route pero nada, cuando hago un tracert 192.168.20.1 de la sucursal A a la sucursal C, los paquetes de datos se quedan en la 192.168.10.1, osea parece que la central no los deja pasar al otro router.
Saludos.
puedes hacer un
show ip route en la central y adjuntarme la por favor
saludos
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is 200.124.246.65 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 200.124.246.65
      10.0.0.0/8 is variably subnetted, 5 subnets, 3 masks
C        10.1.1.0/24 is directly connected, BVI100
L        10.1.1.1/32 is directly connected, BVI100
C        10.1.10.0/30 is directly connected, Loopback0
S        10.1.10.1/32 is directly connected, Integrated-Service-Engine0/0
L        10.1.10.2/32 is directly connected, Loopback0
      192.168.4.0/32 is subnetted, 1 subnets
S        192.168.4.1 [254/0] via 200.124.246.65, FastEthernet0/0
      192.168.10.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.10.0/24 is directly connected, BVI1
L        192.168.10.1/32 is directly connected, BVI1
S     192.168.75.0/24 [1/0] via 0.0.0.0, Virtual-Access2
      200.124.246.0/24 is variably subnetted, 2 subnets, 2 masks
C        200.124.246.64/26 is directly connected, FastEthernet0/0
L        200.124.246.120/32 is directly connected, FastEthernet0/0
dos cosas.
1) Me parece que no tenemos una ruta de la central a la sucursal c, Pruebe haciendo ping desde la central a la sucursal c
2) Si  el ping no se logra aplique en la central este comando
ip route 192.168.20.0  interface o ip del siguiente salto
Saludos
el comando es ip route 192.168.20.0 255.255.255.0 interface local o ip del siguiente salto.
lo recomendable es colocar la ip del siguiente salto
por favor calificarme si te ayuda mi respuesta
saludos
De la central a las dos sucursales si tengo comunicacion, de la sucursal A a la central tengo comunicacion,
de la sucursal C a la central tengo comunicacion, pero de la sucursal A a la sucursal C no, cabe mencionar que todo esta enlazado a traves de una VPN, pongo un pequeño diagrama
