how to configure sip trunk cisco uc560
valente.13
I purchased a cisco UC560 with bri and wanted to know how to set up a sip trunk.
Thank you
Rosica Sareva
Hello Valente.13,
Do you plan to use the Cisco Configuration Assistant (CCA) for configuring your UC560 or the command line?
The CCA, although not being supported anymore, like the UC560 as well, can still be downloaded here: https://software.cisco.com/download/home/281010085/type/281161599/release/3.2%25283%2529
It has nice and very intuitive GUI and admin guide as well.
Here is a step-by-step guide: https://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=7f8fd7feacbb4f308ca44529ad6561d4_Configuring_Generic_SIP_Trunk_on_UC500_Series.xml&pid=2&converted=0
If you plan to configure it via CLI - the UC560 is with CME 8.6 actually, so commands will be the same like for the CME.
Thank you for your help
