05-14-2009 07:20 AM - edited 03-21-2019 01:06 AM
I've got a spa9000 v2.
I'd like create a path for incoming call.
first i want to ring the ext:203 then all the phone.
I create un hunt grourt : 999:name="Tous",201,202,204,205,206,207,208,209,210,hunt=al;14;1
in my contact list i've got : 203,cfwd=999
Cfwd No Ans Delay:10
this configuration doesn't work...
where is my mistake ?
sincerly,
Loic
Solved! Go to Solution.
05-14-2009 09:48 AM
Hi Loic,
You do not have a mistake in your configuration. The SPA9000 does not support forwarding to a hunt group.
Refer to this conversation: https://www.myciscocommunity.com/message/5927#5927
Patrick
05-14-2009 09:48 AM
Hi Loic,
Patrick
05-15-2009 12:22 AM
Ok,
thx a lot.
last question :
the spa9000 can do that ?
contact list : 999,cfwd 205,206
Loic
05-19-2009 03:50 AM
Hi Loic,
No, I don't believe that contact list : 999,cfwd 205,206 would work.
To achieve similar functionality, you could configure a shared line, example 207 and have multiple phones subscribe to the shared line. This shared line could be the target of missed calls. This way multiple phones would ring when a call is forwarded to the shared line.
Patrick
