Bookmark
Subscribe
4627
incorrect time cp7945 - uc520
ELIE IBRAHIM
Hello
i have UC520 with cp7945 ip phone
displaying the time on the uc520 "show clock" is 1 hour ahead of the cp7945
this started the 1st week of October the clock on the phones changed i waited till today so the timezone changes but the phones did not
can someone help in this matter
Elie,
It doesn't look like a bug; I can't reproduce your issue in my lab.  I can configure EET on my router and get the right time on all devices.  You've got something wrong on your side somewhere.  Open a TAC case if this post still doesn't help.
Here is the output from my lab:
pod3-3825#sh run | i clock
clock timezone EET 2
clock summer-time DST recurring last Sun Mar 0:00 last Sun Oct 0:00 1
pod3-3825#sh ver
Cisco IOS Software, 3800 Software (C3825-IPVOICE_IVS-M), Version 15.0(1)XA3, RELEASE SOFTWARE (fc1)
pod3-3825#sh clock
15:20:42.803 EET Fri Nov 5 2010
pod3-3825#sh ephone ph | i 45
SEP001D705F2DDB    SCCP45.8-5-3S          SCCP45.8-5-3S         Reset-Reset
pod3-3825#sh telephony-service tftp-bindings | i SEP001D705F2DDB
tftp-server system:/its/vrf1/XMLDefault7945.cnf.xml alias SEP001D705F2DDB.cnf.xml
pod3-3825#more system:/its/vrf1/XMLDefault7945.cnf.xml | i one
E. Europe Standard/Daylight Time
(See attached screenshot for timezone and clock setting on phone.)
You should use the commands I used above and verify if the phone is getting the right time zone in the config, and what the current time of the phone is compared to the router.
FWIW, your DST times are incorrect.  DST happens at midnight for your timezone.  Also, you should be naming your timezone EET, since UTC is incorrect unless your timezone offset is 0.
6 Replies 6
David Hornstein
Level 7
Level 7
My setting are for East Standard/daylight savings time in the USA, you can adjust accordingly;
Find a NTP server closer to home :-) see if this makes a difference over time.
show run | include clock
clock timezone EST -5
clock summer-time EDT recurring
config term
UC520(config)#ntp peer pool.ntp.org
Translating "pool.ntp.org"...domain server (209.18.47.61) [OK]
UC520(config)#do show clock
08:04:56.145 EDT Mon Nov 1 2010
UC520(config)#
UC520(config)#sh clock
% Invalid input detected at '^' marker.
UC520(config)#telep
UC520(config)#telephony-service
UC520(config-telephony)#time-zone ?
  <1-53>  select timezone name used by IP phones (offset in minutes)
1 Dateline Standard Time -720
2 Samoa Standard Time -660
3 Hawaiian Standard Time -600
4 Alaskan Standard/Daylight Time -540
5 Pacific Standard/Daylight Time -480
6 Mountain Standard/Daylight Time -420
7 US Mountain Standard Time -420
8 Central Standard/Daylight Time -360
9 Mexico Standard/Daylight Time -360
10 Canada Central Standard Time -360
11 SA Pacific Standard Time -300
12 Eastern Standard/Daylight Time -300
13 US Eastern Standard Time -300
14 Atlantic Standard/Daylight Time -240
15 SA Western Standard Time -240
16 Newfoundland Standard/Daylight Time -210
17 E. South America Standard/Daylight Time -180
18 SA Eastern Standard Time -180
19 Mid-Atlantic Standard/Daylight Time -120
20 Azores Standard/Daylight Time -60
21 GMT Standard/Daylight Time +0
22 Greenwich Standard Time +0
23 W. Europe Standard/Daylight Time +60
24 GTB Standard/Daylight Time +60
25 Egypt Standard/Daylight Time +60
26 E. Europe Standard/Daylight Time +60
27 Romance Standard/Daylight Time +120
28 Central Europe Standard/Daylight Time +120
29 South Africa Standard Time +120
30 Jerusalem Standard/Daylight Time +120
31 Saudi Arabia Standard Time +180
32 Russian Standard/Daylight Time +180
33 Iran Standard/Daylight Time +210
34 Caucasus Standard/Daylight Time +240
35 Arabian Standard Time +240
36 Afghanistan Standard Time +270
37 West Asia Standard Time +300
38 Ekaterinburg Standard Time +300
39 India Standard Time +330
40 Central Asia Standard Time +360
41 SE Asia Standard Time +420
42 China Standard/Daylight Time +480
43 Taipei Standard Time +480
44 Tokyo Standard Time +540
45 Cen. Australia Standard/Daylight Time +570
46 AUS Central Standard Time +570
47 E. Australia Standard Time +600
48 AUS Eastern Standard/Daylight Time +600
49 West Pacific Standard Time +600
50 Tasmania Standard/Daylight Time +600
51 Central Pacific Standard Time +660
52 Fiji Standard Time +720
53 New Zealand Standard/Daylight Time +720
UC520(config-telephony)#time-zone 12
UC520(config-telephony)#crea cnf
Creating CNF files
UC520(config-telephony)#exit
UC520(config)#exit
UC520#wr
Building configuration...
Compressed configuration from 41986 bytes to 20451 bytes[OK]
UC520#
thanks for your reply
i tried that and it did not work
the stange thing is that the cp7940 phones have correct time
my clock settings are
clock timezone UTC 2
clock summer-time UTC recurring last Sun Mar 3:00 last Sun Oct 4:00
telephony-service
time-zone 28
i think this is related to the 7945, i installed the latest software pack  8.0.4 and still the same
Since you mentioned that the issue occurred today, it's an issue with DST.
7940 phones get the time directly from the local time on the router.  7945 get the time in UTC format from the router (which is determined by IOS applying the clock offset off the local time), and re-applying the offset again at the endpoint itself based on the config in tele-service.
* Time zone on tele-service and on the router clock look right.
* DST settings on the router look right.
So things to check:
* Make sure that 'sh clock' shows the correct local time.
* Make sure that all of your ephones have a 'type' specified under them.
* Rebuild the CNF files with 'telephony-service/no cre cnf' and then issue 'cre cnf'.  Reset the 7945s.
* Verify that the 7945s are running recent phone loads with the output of 'sh ephone ph'
If the time is still off, submit the following and I will look into it being a possible bug:
sh clock
sh run
sh ephone ph
sh ver
thanks Steve
i did all you mentioned still having incorrect clock on 7945
attached
sh clock, sh ephone ph, sh ver : sh.txt
sh run  : shRun.txt
Elie,
pod3-3825#sh ver
pod3-3825#sh clock
Thanks Steven
i changed  telephony-services time-zone to East Europe  recreated cnf files and it worked
