08-18-2010 04:19 PM - edited 03-21-2019 02:53 AM
Hello!
Just had a question regarding an external DHCP server for a UC 540. I have added the "IP helper-address" command to "Interface BVI 1". Everything works ok, my computers get a dhcp address but as soon as I try pinging from CUE out to the internet, I get no reply. Now, if I add the "IP NAT OUTSIDE" command to the BVI 1 interface, CUE is able to ping outwards but I cannot access the CUE through web browser. Is there any way to configre this so that CUE is able to ping out to the internet (need this for SMTP message notification) and DHCP addresses for computers come from an external server while the Phones get their IP address from the UC540 system?
It almost seems like you can only have one or the other? Also, I will be programming through CLI.
Thank you!!
08-23-2010 12:58 AM
Please provide a diagram that depicts your suggested topology, so we can try to help.
Note which vlans and IP addressing you wish.
Also point out your routing points.
Victor
08-23-2010 11:03 AM
08-23-2010 11:06 AM
Sorry,
I accidently labled the UC540 as a 560. I am currently working on a 540 but seem to have the same problem with a 560.
08-26-2010 11:20 AM
Does anyone have any idea?
