POES5 - PoE adapter for SPA303
ciscodotcom1
Does anyone know whether there is a replacement for the POES5 which went end of life Sept 2014?
Failing that can anyone recommend a suitable device please.
Cheers
Jon
Dan Lukes
Note 1: it still can be ordered from some shops
Note 2: there is no replacement for such product from Cisco
Note 3: consider SPA50x product line - it require no external splitter as there is embedded one
According replacement from other vendor ...
... I have no personal experience, but I wish that any 5-volt PoE Splitter with appropriate connector will work ...
Dan Lukes
Dan
Thank you for the quick reply.   I'm going to try various things and see what I can get working.  The SPA303 is an absolute winner due to price ...
Cheers
Jon
