RE: SPA525G white screen since update to spa525g-7-5-4-bt.bin
propharmarenens
Today I updated my phone to the latest firmware (spa525g-7-5-4-bt.bin). After the reboot the phone displayed a blank white screen. The update process worked, I can access the web interface I can send and receive calls, the firmware on the phone is 7.5.4 but the screen remains white.
I tried to downgrade the phone to my initial firmware version (7.4.8) but the problem is the same. I tried to reset the phone to factory settings with no luck.
Hope someone could help me, an IP phone with an blank white screen isn't verty usefull.
Regards.
6 Replies 6
yajoshi
Hi Nicolas,
Thanks for providing a detailed description of the issue.
I have several SPA525G phones in my Lab and have been moving them back and forth between the versions 7-5-x and 7-4-x with no problems. It seems strange for the display to go blank abruptly.
Can you please send a screenshot of the screen ?
Was there anything unusual that you noticed while the phone was upgrading the firmware ?
How many SPA525G phones are we talking about ?
Any other details that you would want to highlight would be good.
Action Plan:
>> Please try factory resetting the phone once and check if the display changes.
>> Once factory reset try bringing it back to the firmware 7-5-4.
Hope this helps !
Yash Joshi
CCIE Voice #  31109
Regards Yash Joshi CCIE Voice # 31109
Hi Yash,
thanks for taking time to answer.
We have 4 phones in our office and I started upgrading one. Always better to brick one instead of four , so yet one phone is crashed. I didn't notice anything strange during the update process, the phone rebooted after the update with the white screen.
If  I configure the phone from the webinterface (provisioning) everything  works except the screen, I can place call, answer, use the bluetooth,  ...
I did a factory reset: started the phone, pressed the  speaker button and selected "recovery reset" then "OK". I did it  simultaneously on another working phone to see what I was doing. The  phone restarted but again with the white screen. I also re-flashed the  phone to the 7.5.4 version.
I installed a syslog-ng server on a  Linux machine to read the syslog of the phone with a level 3 debug but  nothing interesting came up.
Here's a youtube video of my problem: http://www.youtube.com/watch?v=xW9QXIZchMA
Nicolas
Hi Nicolas,
It seems that you have one bad phone with you. I would suggest upgrading the firmware on the second phone and that should work fine. I understand in-case you do not have spare sets with you and will not be willing to do it.
If thats the case, I would suggest getting an RMA done for this phone and having a replacement delivered. If you have a support contract to get a ticket opened with Cisco, replacement should not take much time. Otherwise you can contact the local re-seller to replace the phone.
Let me know your thoughts on this.
Yash Joshi
CCIE Voice # 31109
vern.brownell
Hi there propharmarenes,
I just upgraded by spa525g to spa525g-7-5-4-bt.bin and immediately after the firmware upgrade I now have the identical blank white screen.  Phone functions and is accessable by the network.  Did you ever get resolution to your problem?
Thanks much!
Vern
Hi Vern,
I have the same problem, no change after downgrade, still blanbk white screen.
Is ther a solution in teh meantime or is it an hardware problem?
Ruediger
Hi vern, hi everybody,
For several month I put the bricked SPA525G away and didnt use it. Today I connected it again and got the white screen. I updated it then with the oldest Firmware, I could found (7.1.7), and after reboot....
Hurray!!! Ithe display was back again.
So I tried to update again the newest version (7.5.6) and.......oh no...it is white again.
So I decide to let it on the oldest Firmware, but this time, it does not work. The screen stays white!
What a mess, why did I made the update...
I booted several times and test several Versions of the firmware. Nothing happend. Sometimes I could see the menu very pale. Looks like there is not enough contact or so.
Puh. I tried several temperatures, cold, hot...hmmmm ... nothing
Ok I put it away for some month again, ....
Somebody else, who has this problem and find a solution?
Pasadena
