08-05-2009 01:59 PM - edited 03-21-2019 01:23 AM
I have IP Communicator running against a UC500 box in my office fine.
I have a client with a similar config. They are using a Netscrren firewall with VPN.
I can ping and access the GUI for the UC500. I have added the CIPC into the config so the phone is listed but I cannot get it to register to the call manager.
Under device I keep getting either unavail or standby
Any help or ideas.
Todd
08-05-2009 02:10 PM
What IP did you assign the TFTP server over the VPN? Can you ping that IP when you are using the VPN?
08-05-2009 02:19 PM
The TFTP IP in the phone preferences is 172.30.100.254 which is the voice VLAN and the IP of the Voice VLAN on the UC500. I can access the GUI using that IP over VPN.
I think there is a code issue. I have no issue on my UC500 but I am on 7 code and the phone registers in the GUI as a CIPC whereas on the other system it is unknown.
08-05-2009 02:29 PM
Try a debug tftp events on the uc500 that is having the problem. That will tell you if the request is getting there. If it is, I would then try debug tftp packets to make sure the files are making it back.
