03-10-2010 07:54 AM - edited 03-21-2019 02:17 AM
Is there anyway to reroute an outgoing call through another fxo port in the spa400 if the line is already being used?
thanks
03-10-2010 10:52 AM
This type of dial out should be working if you used the wizard to install the spa9000, spa phones and spa400. spa9000 would route the call to the spa400 which would route the outbound call through a free line.
03-10-2010 10:59 AM
ok thanks for the answer. My dial plans works perfect but i use the L2{0} and L2{1} steering digits a dial plan where numbers that start with 9 get sent out through L2{0} and numbers that star with 6 get sent out through L2{1}. I was wondering if it was posible that if someone dialed a number starting with 9 and was usuing that line if there was anyway to use the following FXO port .
thanks
