SPA 303 Stuck at initilizing network
Sage Major
When installing 303's we have some that will not pick up an ip address and stay at initilizing network.  The computer plugged in through time will connect to the internet.  Rebooting and re-plugging in cables does not seem to fix it.  Other spa 303's in the same place will work.  That 303 will not work into any port of the router.  The phone will work going into some other router.
We have run into this issue several times and 2 in the last week.  Both phones worked when plulgged into a Adtran router but not when plugged into a Cisco spr521.
Sage
nseto
Level 6
Level 6
Go to the system tab and under VLAN settings, try turning off CDP and LLDP and see what happens.
9 Replies 9
nseto
Level 6
Level 6
That solved it at two different instaliations.  Thanks.  We were having to go out and configure static ip's onto each phone that had the issue.
Thank you Very Very Very Very Much
I Disabled CDP and LLDP and it worked like magic
May god bless you friend, You have saved my life.
Many Thanks,
Fawzy
stuartkatz
I have this same error and can;t find the system tab on the phone to go to VLAN settings.  Tried rebooting the router too but that didn't help.
No system tab at all ?
You are not logged as administrator.
Never had to login as administrator -- how would I do that?  We're a one man company
Be sure phone know no number of mans in your company, thus it can't modify the behavior based on it.
See upper right corner:
jbdough01
creating new thread for same problem not solved by Correct Answer
This thread has been claimed "Answered Question". If you are affected by the same issue use the Correct Answer provided already.
If you are affected by other issue create brand new thread for it, please.
Thank you for your understanting.
