10-28-2010 08:53 AM - edited 03-21-2019 03:11 AM
I'm using the SPA962, and having an issue with numerical button presses, IE: If I call a bank or any service that requries me to type any sort of numerical code, the receiving side gets codes like (5555 22222 33 - if I had only dialed 523). Not quite sure how to remedy this, any suggestions would be greatly appreciated.
EDIT: oh, and all firmware is up to date
Solved! Go to Solution.
10-28-2010 11:35 AM
You can try the other dtmf sending options to see if there's a difference.
Located in the Ext tab under audio config. DTMF Tx Method. AVT, Info or Inband.
10-28-2010 11:35 AM
10-28-2010 12:55 PM
Inband seems to be the answer.
Thank you very much nseto!
