SPA IP Phone - * (Star Key) not working using 3rd party conference service
robert
Hi - I have an SPA 504G  with SIP service and use a third party conference service to host conference call.  The 3rd party service requires me to log in as the Leader and to do this I have to press the * key.  This doesn't work possibly becuse * has been configured as a short action code.
Does anyone know of a way to disable short codes (*) whilst a call is in progress?
Dan Lukes
Then deconfiguration of such action codes and/or relevant supplemental services should solve your problem.
It may help you to know that I have no problem using * against remote IVR with the following configuration (SPA508G with firmware 7.5.4):
Vertical Service Activation Codes
Call Return Code:    Blind Transfer Code:
Call Back Act Code:    *4Call Back Deact Code:    #4
Cfwd All Act Code:    *21Cfwd All Deact Code:    #21
Cfwd Busy Act Code:    *67Cfwd Busy Deact Code:    #67
Cfwd No Ans Act Code:    *61Cfwd No Ans Deact Code:    #61
CW Act Code:    CW Deact Code:
CW Per Call Act Code:    CW Per Call Deact Code:
Block CID Act Code:    Block CID Deact Code:
Block CID Per Call Act Code:    Block CID Per Call Deact Code:
Block ANC Act Code:    Block ANC Deact Code:
DND Act Code:    *85DND Deact Code:    #85
Secure All Call Act Code:    Secure No Call Act Code:
Secure One Call Act Code:    Secure One Call Deact Code:
Paging Code:    Call Park Code:
Call Pickup Code:    *1Call UnPark Code:
Group Call Pickup Code:    *1Media Loopback Code:
Referral Services Codes:
Feature Dial Services Codes:     *61*`c`|*21*`c`
Supplementary Services
Conference Serv:    Attn Transfer Serv:
Blind Transfer Serv:    DND Serv:
Block ANC Serv:    Call Back Serv:
Block CID Serv:    Secure Call Serv:
Cfwd All Serv:    Cfwd Busy Serv:
Cfwd No Ans Serv:    Paging Serv:
Call Park Serv:    Call Pick Up Serv:
ACD Login Serv:    Group Call Pick Up Serv:
ACD Ext:    Service Annc Serv:
