03-29-2017 11:05 AM - edited 03-21-2019 10:39 AM
I am provisioning an SPA112 firmware version 1.4.1 for Broadsoft. I change the admin and guest password in the config file. When the SPA112 recovers I am still able to use the default login. Below are my changes. Any assistance would be greatly appreciated.
03-29-2017 11:47 AM
Those commands are not root level commands. They are part of <router-configuration>...</router-configuration> block.
I would like to recommend you - save the SPA112 configuration (in XML form), make required changes then reload it back.
03-29-2017 01:45 PM
Dan,
Thank you for your response. I added this into the config file outside of the <router-configuration>...</router-configuration>
03-29-2017 02:15 PM
Both commands you mentioned doesn't exists on SPA112 at all, thus, you changed nothing and defaults apply.
03-29-2017 02:29 PM
Dan,
Would you happen to have the correct syntax for the SPA1x2 devices?
03-29-2017 02:53 PM
As advised already - save the current configuration to XML file. You will know all options known to SPA112 including correct context.
