Hi everyone, i trying to use a SPA3000 and SPA3102 to make and receive call with PSTN (FXO)
It's working fine
I have a PSTN Line registered in a SIP server
User ID: 1001
Config a dialplan
Dial Plan 1: (<:06732011173>S0)
Dial Plan 2: (xx.)
And config a VoIP Users and Passwords (HTTP Authentication)
VoIP User 1 Auth ID: pstn-out
VoIP User 1 DP: 2
So, i can receive calls from PSTN and send to SIP Server via SIP
In SIP server i see user 1001 -> 06732011173
And I can make calls from SIP Server, using the SPA Gateway (pstn-out)
But, if in a middle of PSTN call, i try to make a outbound call (using gateway)
I receive a 504 Server Time-out (in FreeSwitch is 102 RECOVERY_ON_TIMER_EXPIRE)
I think this is correct, since the line is in use, and i can't make calls.
Buf after a few seconds, sometimes and the same time, i receive a new call from PSTN (INVITE)
And, if i send this to a IVR, i hear the audio in first call
If i hangup, the first call hangup too.
Is there someone who can help me?
