SPA303 IP phone clock settings default to factory setting at every provisioning reset. How to avoid?
Ed Jennings
My Cisco IP phone defaults to factory set time at each provisioning reset requiring me to manually reset time to current.  How do I change settings to avoid this?  I can't find a configuration setting for this.
edit:  actually, it appears that the time reset was associated with power interruptions, not SIP provisioning.
Ed Jennings
I made an uninformed change: I went to
Optional Network Configuration:
DNS Server Order- DHCP, Manual  (originally was Manual)
Primary NTP Server: time.windows.com  (originally was blank)
... and hit submit.  I will not know if this made my correction or not until another power interruption, but the time continues to show correctly, so nothing bad has happened (I hope).
Do you configure ntp server in your CME?
