SPA3102 SIP call from mobile phone
onlineuser
I am using a SPA3102 for outgoing calls from my analogue phone. It works with two VoIP gateways (line1 - voipbuster.com and voipdiscount.com) and on PSTN I use sipcall.ch).
Now I want to make outgoing calls with my mobile. I added a user on SPA3102 but when I try to call any phone number from mobile the SPA3102 does nothing (the incoming connection from mobile to SPA3102 works) but the SPA3102 does not open any outgoing connections to one of the three providers.
Is there a problem with my dial plan (I also tried the default settings). The syslog information is also not very meaningful.
Thanks, a lot.
Dan Lukes
While I can guess how you have connected analog phone to SPA3102, I have no idea how you are connecting your mobile phone to SPA3102. Neither SPA3102 nor mobile phone have port suitable for interconnection.Assuming you are using term "mobile phone" for a cellular phone like GSM phone or so.
Can you describe your topology ?
