07-14-2011 09:05 AM - last edited on 03-25-2019 10:58 PM by ciscomoderator
Hello All,
Does anyone know if the SPA504G phones will work with a Third Party switch such as a Dell Power Connect?
Does the UC540 support intergration with Microsoft Lync?
Any supporting links would be great because I have been searching without luck?
Rich
12-02-2011 11:13 AM
Hello Rich,
we had the same idea. But i do not think cisco will implement that.
Anyway we are trying to create a client side windows service, that captures the status of spa500 phones and sets the lync status when you are calling. That would at least give us a bit of integration. We are using Lync Online with Office 365.
We are still in a very early phase, but our experiments work amazingly good.
Would you be interested in that solution if it works?
Max
12-04-2011 01:32 AM
Hi Richard,
Yes but do not expect it to work as well as it would on a Cisco Switch, also no support of you have any issues with phones not registering or voice quality issues or any other issue for that matter, unless the problem resides on the itself. You will also need to make sure that the ports are setup correctly and to the right class, if the HP does not automatically change the class type you can fry the phones and you should see what happens to the screens (Yes don't ask, it was an experiment at a School that went horribly wrong).
Yes but not officially, I have made a previous post on here to another thread of the same question and provided documentation and also links to how to get it to work. I believe Cisco and MS are working on this and maybe sometime next year you will see it integrated into but count on it being done quickly, these things take time to get into build maps.
I dont have the files with me as I am not working much these days with Cisco Products, and I cannot find the USB pen drive where I had all my files on Otherwise I would list them back up, but if you look on the subject in the search bar you will find it, to click on my name and go to my profile and look at my posting history.
Cheers,
David.
