SPA504G and 502G pass locked
AntalVincz
Hi All,
How to open pass locked, forgot admin pass SPA502G and 504G phones?
I try used the fw updater (spa50x-30x-7-6-1.exe), but don't work, it is also asking for a password.
How to interpret this?
If you are the administrator and forgot the password, you may perform a factory reset by entering ****, option 73738#, and value 1 from a telephone connected to the unit to be upgraded.
Thank you any help!
Tony
Jaime Valencia
SPA endpoints are covered in the SMB community.
java
if this helps, please rate
Ok.
What is SMB community address?
Thanks I found.
Hover over Directory in the top bar, see low right corner.
java
Dan Lukes
Duplicate of SPA502G and 504G
