SPA508G Ringing loudly
Hello, any advice on how to turn the ringer down? We have turned it down and while ringing and saved it. Still very loud.
Dan Lukes
You set ringing volume to 1 and it's still loud for you ? Ringing volume can't be set to zero. It can be muted, but didn't mentioned you wish to mute ringing at all.
But you may create your own ringing. If it will be not so loud in the base, it may satisfy you when played at volume level 1 ...
