For some reason I cannot get to provision the admin and/or user password from a provisioning server.
Everything else in the big XML received by the phone gets into the configuration.
Snippet from the XML being delivered to the phon
<!--System Configuration-->
<Restricted_Access_Domains ua="na"></Restricted_Access_Domains>
<Enable_Web_Server ua="na">Yes</Enable_Web_Server>
<Enable_WAN_WebServer ua="na">Yes</Enable_WAN_WebServer>
<Web_Server_Port ua="na">80</Web_Server_Port>
<WAN_Web_Server_Port ua="na">8181</WAN_Web_Server_Port>
<Enable_Web_Admin_Access ua="na">Yes</Enable_Web_Admin_Access>
<Admin_Passwd group="System/System_Configuration" ua="na">XXXXXXX</Admin_Passwd>
<User_Passwd group="System/System_Configuration" ua="na">YYYYYY</User_Passwd>
<SPA525-auto-detect-sccp group="System/System_Configuration" ua="na">No</SPA525-auto-detect-sccp>
<Phone-UI-readonly group="System/System_Configuration" ua="na">No</Phone-UI-readonly>
<Phone-UI-user-mode group="System/System_Configuration" ua="na">Yes</Phone-UI-user-mode>
<QOS_QDisc ua="na">NONE</QOS_QDisc>
The only way to set the password is to use the web admin gui.
Any bright ideas ?
