UC320W + GSM Gateways
flamaison
Hi all,
I'm struggling with cheap GMS Gateways to connect on my FXO ports. Unfortunately in The Congo we don't have land line and slow Internet so I'm stuck using GSM Gateways.
I'm planning on buying good quality gateways to work with my UC320W and I saw it was possible to have something like this:
GSM Network => SIP trunk (the gateway) => SIP line (UC320W)
This product seems to do the job:
http://www.2n.cz/en/products/gsm-gateways/voip/voiceblue-next/
Do you guys already worked with this type of gateways? Any advice on the model that will work with the UC320W?
If it's not possible to use this type of gateway, I'm looking for good quality GSM/Analog gateway, any advice ?
Best regards,
0 Replies 0
