This is the second UC540 I've deployed and know it well however; after changing the integrated service module from the standard IP, the MWI stopped functioning. Everything else is functioning just fine.
Going through the debugs, below is what I've noticed. I know there are some obvious errors but all settings should be correct as the only thing that changes is the module IP. Any ideas?
CALL_CONNECTION_ACTIVE
EVCall=SIP-Call-13:ACTIVE[A80056311:IDLE,56399:ACTIVE]EVConn=[SIP-Conn-26, dn=56399, call=B806EDC7-014C-1000-48D6-A2B2C8D698FC, state=ACTIVE]
ctrl=[ltp25], MT=[[SIP-Local-MT-24 dn=56399 media=172.30.203.29:32785, mediaStarted=false]]
, cause=ORIGINATED
3432 04/14 09:03:24.184 ACCN SIPL 0 SIP-Call-13, GCID=B806EDC7-014C-1000-48D6-A2B2C8D698FC dispatch to com.cisco.wf.subsystems.callcontrol.AppCallListener@1ba67ec
3432 04/14 09:03:24.186 ACCN SIPL 0 SIP-Call-13, GCID=B806EDC7-014C-1000-48D6-A2B2C8D698FC dispatch to com.cisco.wf.subsystems.callcontrol.AppRoutePointCallListener@1ed13da
3432 04/14 09:03:24.186 ACCN SIPL 0 SIP-Call-13:ACTIVE[A80056311:IDLE,56399:ACTIVE] setIgnoreConnectionActiveEvent to true
3575 04/14 09:03:24.195 ACCN SIPL 0 ltp25-56399, State=CONTACTING: invitation rejected
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 172.30.203.29:5060;branch=z9hG4bK4yHXDEw+b08YughpsJzfGg~~9
To: <sip:A80056311@172.30.203.29:5060>;tag=dsdae9a767
Call-ID: 14290166041039@172.30.203.29
CSeq: 100 INVITE
Content-Length: 0
3575 04/14 09:03:24.195 ACCN SIPL 0 SIP-Call-13:ACTIVE[56399:ACTIVE], remove connection A80056311, last=false
3575 04/14 09:03:24.195 ACCN SIPL 0 [Conn-25-A80056311] onCallConnectionFailed: state=IDLE, cause=INVALID_DESTINATION
3575 04/14 09:03:24.195 ACCN SIPL 0 [Conn-25-A80056311] setState: IDLE -> FAILED
3575 04/14 09:03:24.196 ACCN SIPL 0 CallImpl.notifyAllListeners: ev=CALL_CONNECTION_FAILED (A80056311) call=SIP-Call-13:ACTIVE[56399:ACTIVE]
EVCall=SIP-Call-13:ACTIVE[56399:ACTIVE]EVConn=[SIP-Conn-25, dn=A80056311, call=B806EDC7-014C-1000-48D6-A2B2C8D698FC, state=FAILED]
ctrl=[CSTA-SC-24], MT=[[SIP-Remote-MT-25 dn=A80056311 no media]]
