Hi Gary,
Yes you can configure a SIP trunk to function on this system, you just need an ITSP provider, they can then allow for the 4 incoming connections to the UC-500 over the SIP trunk, looking at the DSL connection you have enough upstream bandwidth to cater for 4 simultaneous calls, but this might be effected with data moving across the link at the same time, unless you have end-to-end QoS enabled (Must be done at your and and the ISP needs to apply it on the DSL link).
Other than that I why wouldn't you use all the capacity on the system? You have a BRI card which is ISDN and you have FXO which is PSTN, or is this capacity not enough???
It would appear you have more than one option available to you
Cheers,
David.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
