UC560 - SIP does not work
nicolas95
I can not configure my SIP account OVH on UC560.
My account works with the software Zoiper (see image config).
My account does not work with Cisco UC560 (see image config).
If anyone can help me to understand and configure properly.
Thank you in advance
9 Replies 9
mcasimirc63
Level 4
Level 4
You might be running into an issue because the username contains letters. Your sip provider might expect sip invites to come from your username instead of your registered telephone number.  CCA will only accept numbers for an outbound dial plan.  You should be able to register and you might be able to receive calls but you might have an issue placing calls.
Thank's
There are no letters in the username. The "xxxx" is just to hide the phone number.
Another idea? you all seem correct?
In CCA under the troubleshoot tab could you type in debug ccsip events and debug ccsip messages?  Make a phone call after you have done that and then post your results here.
Debug files here.
I'm still not quite comfortable, thank you for your help.
If you go under Sip trunk status. Does it show that your trunk has been registered?
It seems correct (see attached image).
I send you by MP access to the UC560 by LogMeIn.
Maybe it will be easier for you.
Thank you again for your help.
Additionally, you might want to check with your provider to see if you have the correct settings entered for you SIP profile. Your debug came up with these messages when you made an outbound call.
Sent:
INVITE sip:0624113224@ns11.ovh.net:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.10:5060;branch=z9hG4bK481BF4
From: "Ventes eAv" <>0183629060@sip.ovh.net>;tag=459DD80-1E7F
To: <>0624113224@ns11.ovh.net>
Date: Wed, 02 Feb 2011 09:59:07 GMT
Call-ID: E85F6A5A-2DE911E0-811BA552-C13DB3E4@sip.ovh.net
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3843486895-0770249184-2165679442-3242046436
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
000889: Feb  2 10:59:07.111: //137/E516F4AF8115/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 400 Wrong domain
Allow: UPDATE,REFER,INFO
Contact: <91.121.129.17:5060>
CSeq: 101 INVITE
Server: Cirpack/v4.42s (gw_sip)
To: <>0624113224@ns11.ovh.net>;tag=00-07992-2e1106b7-29ca485e3
Via: SIP/2.0/UDP 192.168.0.10:5060;received=82.237.12.225;rport=53442;branch=z9hG4bK481BF4
Content-Length: 0
I just got the response from the provider OVH.
They say if it works with the software Zoiper is a problem with configuring Cisco. And it does not concern them.
I do not know what to do. I have to put into production in 10 days.
Thank you for the help.
Nicolas
Eureka, it works.
It appears that the SIP password can not be filled by copy / paste.
I just seize the password with the keyboard and everything works fine.
I'll continue my setup.
Thank you for your help.
