Bookmark
Subscribe
765
Unable to set backlight on SPA-962
taylornelson
I am unable to set a backlight timeout on my SPA 962. I have heard this was an issue with the latest firmware, but there has never been a newer version released.
Does anyone know how to fix this? Or perhaps know of a workaround, other than using the screensaver. I say that because, using the screen saver method, only makes the screen go black, it doesn't dim the backlight.
sas777
up
SPA-962, Software Version: 6.1.5(a)
Does anyone know a working solution to turn off the backlight on a timer?
There is a parameter in the phone menu - `Settings -> (5) Parameters -> (11) Backlight timer` but it does not work, changes to the values ​​​​in it are not saved.
In the config http://192.168.0.7/admin/spacfg.xml there is no tag corresponding to the backlight timer settings.
