01-21-2010 06:12 AM - edited 03-21-2019 02:03 AM
In updating a UC 520 to fix a bug in IOS, we have run into a small difficulty.
No matter what we do, the update fails during the CME part of the update. We were able to successfully update IOS but then we get a TFTP error. The error insists that another TFTP server is running. It is not. Ran a netstat -an and verified no open ports or services were running that would give this indication.
A growing consensus here is that the flash memory has a bad sector. We don't really know what the behavior of a UC 520 would be with a bad flash memory so this is speculation but what else could it be?
We have tried downloading the update on 3 different computers 3 different times, and running the update from each separate location with the same result.
Is there a way to use CCA to verify the status of the flash?
Is there some other process within the UC 520 that could be interfering with the update?
We are fully functional right now but I worry when everything is not working perfectly.
Solved! Go to Solution.
01-21-2010 07:36 AM
Use CCA's dashboard (under HOME Drawer) to check the % utilization of flash. If 90% or more, CCA may be blocking the update since it cant fit all the phone loads (part of the CME upgrade).
Use Phone Load Manager to only select the models you desire and also select auto format flash in the upgrade options to allow CCA to make directories on flash.
Steve
01-21-2010 07:36 AM
Steve
01-21-2010 11:34 AM
I have the flash utilization down to 58% by already doing that. Still get the same tftp error during the CME portion of the upgrade. We are a bit wary of playing around with this too much. Lost our entire flash contents Monday and knocked us offline for 4 hours. Needless to say, management is not amused.
01-24-2010 04:09 PM
Look over this checklist and if still happening, call support (UC520 is TAC)
01-25-2010 06:23 AM
Thanks for the response. I have attached a text showing a couple of settings that differ from yours. TAC is not a readily available option for us. We purchased our UC 520 through Cisco sales to help us sell the product (we have sold 3 this year) and we do not have a support contract. It is up to us (me) to keep this system running. We had no problem with updates to our flash until this one.
Is there a way to verify the integrity of the flash memory? I am sure the TFTP error we are seeing is related to the UC 520. I am hopeful that it might be something easily repaired like a bad flash. Otherwise, we will just have to live with this until it quits working.
02-02-2010 11:23 AM
If you can collect the CCA Log for this, I can see if we can have someone look at it.
02-19-2010 01:19 PM
02-19-2010 01:36 PM
I hear ya on the snow. Even in N.C. we got some, but not like the North.
I sent the logs to the CCA team. But if this is urgent, open a case with SBSC (866-606-1866)
Steve
02-20-2010 10:14 AM
Just got feedback on the logs:
The log file I see does not have the logs from the time software upgrade is started.
I do not see any menu being launched. All the log file has is up to the launch of CCA.
I think the best thing to do is open a case with SBSC (866-606-1866) and have them walk you through this.
Thanks!
