I have a 4 ports router and all ports are used. One of them is connected to SPA122 blue port. I want to use the yellow (Ethernet) port as a 5th LAN switch port of the router and connect a printer to it. I set the ATA to bridge mode.
The problem is when I access to the router with ip adress, I only see the 4 devices that are connected directly to its ports, but I cannot see the printer that is connected to the SPA122 yellow port. Therefore, I am not able to print with the device nor access it by ip adress.
Can someone help me?
