Hello, I cannot log in to spa112 web login with admin/admin username and password, neither after factory reset ! I have this answer :Invalid Username or Password.Please Try Again. Please help
is it possible to encrypt the SIP password using MD5 (type 5) as shown below? If not, allowing MD5 encryption should be an easy solution to encrypt the password similar to how the local credentials are encrypted. sip-uacredentials username theuser12...
Hello everyone.I am using an ATA model SPA2012.I am having an issue with audio output gain.In user end, the audio output is too low..I need to increase the audio output volume/gain. Thanks in Advance.
Hello guys. I'm trying to get the 7.6.2 firmware for this phone but in the website when i try to download I get "This file is no longer available to be downloaded" Where can I download the firmware I really need to upgrade the phone it has the 7...
I have a user using a SPA 504g phone. When she presses the soft key for the Missed Calls shortcut, the phone is asking for a password. No other users are having this issue. Is there a way to disable the password for that feature?
When installing 303's we have some that will not pick up an ip address and stay at initilizing network. The computer plugged in through time will connect to the internet. Rebooting and re-plugging in cables does not seem to fix it. Other spa 303's...
Greetings, Can someone her please share their knowledge and experience and guide me regarding which VOIP solution would be appropriate for below scenario A hotel infrastructure with below requirements: SIP Ext.: 300 by default ( max. 500) Concurrent ...
Dear Friends!I have cisco SPA502G at office. Suddenly it lost network.I reset it comparing to the settings of other phone but there is no tone and it give error in Ext 1: Faild (403).Is subscriber info has something to do with this? Please guide me i...
Question: Has the SPA112 VOIP been problematic on LANs in Australia with cellphones using Telstra VoWifi? (Voice calls over Wifi) Background:I'm in Western Australia. ISP = Aussie broadband ('ABB'), an excellent ISP. I use Fixed Wireless broadband an...
I'm trying to configure my UC540 to work over SIP. I have outbound calls working fine. Inbound calls disconnect right away. Here is the output from debug ccsip calls. 002691: Sep 8 07:14:34.760: //-1/25167B2F80FE/SIP/Call/sipSPICallInfo:The Call S...
Hello guys again me!!I figured out with my personal conf the phone.Now i've last 2 question about the conf to make it max useful;)1 question, to male conference call, able to use softkey to make the new call but when try to mix the 2 calls in a confe...
My VoIP provider stated that they allow a blind transfer of a call via the SPA112 but that they don't provide the needed Dial Plan configuration to perform the transfer. Anyone know how to set this up? Here is the default: (*xx|[3469]11|0|00|[2-9]xxx...
hello finally my phone's working well with the correct time and setted linekey for speed dial cuz i've just one line.Now the question is...How to set up softkey rules?HOw to apply them in connected line, off hook and hook?Are there some template or o...
Hi now that i solve my bug and with a simple sep file got my phone in the network and registered wanna solve problem for time.Someone knows of with this version clock problem was solved?And more need 2 option, one to add hiostory calls(recived,missed...
Hi all, i'm new in voip and cisco world. my friend present me a cp8961 and i want to configure it to work with my fritzobx 7590, but no way to solve it. I try to download tftp32 for dhcp and tftp server..but for sure i mistake something. I download t...
