Voicemail to Email not working
Paul Kazzi
Have a site where Exchange mail server is local (192.168.1.5) to UC320 (192.168.1.254). Also UC320 DMZ address is 192.168.3.254.
Cannot send email from UC320. We appear to authenticate correctly with user=voicemailsystem. (Does not work with user= voicemailsystem@company.com)
Aside, when we leave the sensders username and password blank in the "Test SMTP" script, it works.
Exchange has allowed IPs 192.168.1.254 and 192.168.3.254 to relay SMTP but email sending fails with voicemail user. Any ideas before their Exchange admin gets back here in a few days...:
Oct 14 15:57:45 UC320W daemon.info sendmail: sendgetmail_main get WAN ip [192.168.3.254] as EHLO identify
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp check EHLO [192.168.3.254] with code -1
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-SERVER.domain.local Hello [192.168.1.254]
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-SIZE
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-PIPELINING
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-DSN
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-ENHANCEDSTATUSCODES
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-AUTH LOGIN
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-X-EXPS GSSAPI NTLM
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-8BITMIME
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-BINARYMIME
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-CHUNKING
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250-XEXCH50
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 250 XRDST
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp check AUTH LOGIN with code -1
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 334 VXNlcm5hbWU6
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp check  with code 334
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 334 UGFzc3dvcmQ6
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp check  with code 235
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 235 2.7.0 Authentication successful
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp check MAIL FROM:<voicemailsystem> with code 250
Oct 14 15:57:45 UC320W daemon.info sendmail: smtp_checkp get answer 501 5.1.7 Invalid address
Oct 14 15:57:45 UC320W daemon.err sendmail: Set Sender failed
Paul Kazzi
On Exchange run this command to allow open relay after the receive connector is set
Get-ReceiveConnector "voicemail" | Add-ADPermission -User "NT AUTHORITY\ANONYMOUS LOGON" -ExtendedRights "Ms-Exch-SMTP-Accept-Any-Recipient"
