VPN Client broken in IOS 15?
Scott Pettit
Level 9
Level 9
On the UC520 with both IOS 15.0(1)XA1 and XA1a, the VPN client seems to be broken?  The moment I upgrade from 12.4(24)YB4 to 15.0, the VPN client can connect but there is no data transfer.  If I downgrade to 12.4(24) again everything is fine.  I really want to upgrade to IOS 15 to fix a number of other bugs that are annoying me but I can't do so if the VPN client does not work.  AnyConnect still works however this gives us major issues for users with IP Communicator.
Can anyone confirm if this is a bug?  I can't find any mention of it in the bug toolkit.
-Scott
19 Replies 19
Hi Steven, I´m afraid it is still not working, as you pointed i´ve tried deleting the VPN Server config via CCA and setting it again but split tunnel "interesting traffic" is not flowing, I will paste my actual config if you don´t mind checking it out, as you can see I´ve deleted firewall config as well, the VPN clients pool is 192.168.200.0/24, noitce I´ve deleted the WAN address and the crypto key to keep privacy. There´s no traffic matching the slip tunnel ACL (numbered 100 by CCA) while tunnel is up and the VPN client is connected, client version is 5.0.05.0290.
Hope you can find the answer, IOS image is uc500-advipservicesk9-mz.150-1.XA2
Thanks in advance, we´re really bothered about this issue.
! Last configuration change at 10:38:02 PST Mon Mar 29 2010 by satic
! NVRAM config last updated at 10:43:21 PST Mon Mar 29 2010 by satic
version 15.0
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname UC520
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
enable secret 5 $1$pv..$vhQIn99E9IKsFv7Jsl.Cd0
aaa new-model
aaa authentication login local_authen local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authorization exec local_author local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone CET 1
clock summer-time PST recurring
network-clock-participate wic 1
crypto pki trustpoint TP-self-signed-3006563701
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3006563701
revocation-check none
rsakeypair TP-self-signed-3006563701
crypto pki certificate chain TP-self-signed-3006563701
certificate self-signed 01 nvram:IOS-Self-Sig#44.cer
dot11 syslog
no ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp pool phone
   network 10.1.1.0 255.255.255.0
   default-router 10.1.1.1
   option 150 ip 10.1.1.1
ip dhcp pool data
   network 192.168.100.0 255.255.255.0
   default-router 192.168.100.254
   dns-server 8.8.8.8 8.8.4.4
ip domain name satic.local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp supplementary-services
port 0/0/0
  fallback-dn 301
port 0/0/1
  fallback-dn 302
port 0/0/2
  fallback-dn 303
port 0/0/3
  fallback-dn 304
isdn switch-type basic-net3
voice call send-alert
voice rtp send-recv
voice service voip
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
voice-card 0
license udi pid UC520W-8U-2BRI-K9 sn FCZ12066000
archive
log config
  logging enable
  logging size 600
  hidekeys
username satic privilege 15 secret 5 $1$stGP$3nj8BTpRUsFEzHz5KsiXe.
ip tcp synwait-time 10
ip tftp source-interface Loopback0
class-map match-any media
match  dscp ef
class-map match-any signaling
match  dscp cs3
match  dscp af31
policy-map queue
class signaling
    bandwidth percent 5
class media
    priority percent 50
class class-default
    fair-queue
policy-map shape
class class-default
    shape average 500000
  service-policy queue
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key XXXXXXXXXXXXXXXXX
dns 8.8.8.8 8.8.4.4
pool SDM_POOL_1
acl 100
save-password
max-users 10
crypto isakmp profile sdm-ike-profile-1
   match identity group EZVPN_GROUP_1
   client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
   isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
bridge irb
interface Loopback0
ip address 10.1.10.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
interface Null0
no ip unreachables
interface FastEthernet0/0
bandwidth 500
ip address X.X.X.X 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
load-interval 30
duplex auto
speed auto
service-policy output shape
interface Integrated-Service-Engine0/0
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface BRI0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
interface BRI0/1/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Dot11Radio0/5/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Virtual-Template1 type tunnel
ip unnumbered BVI1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 1
interface Vlan100
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 100
interface BVI1
ip address 192.168.100.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip local pool SDM_POOL_1 192.168.200.1 192.168.200.10
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.100.1 3389 interface FastEthernet0/0 3389
ip nat inside source static tcp 192.168.100.1 5500 interface FastEthernet0/0 5500
ip nat inside source static udp 192.168.100.110 69 interface FastEthernet0/0 69
ip nat inside source static tcp 192.168.100.204 9090 interface FastEthernet0/0 9090
ip route 0.0.0.0 0.0.0.0 85.152.7.254
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.100.0 0.0.0.255
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 192.168.100.0 0.0.0.255 any
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
access-list 100 permit ip 10.1.10.0 0.0.0.255 any
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-3.bin alias spa525g-7-4-3.bin
tftp-server flash:/phones/5x5/spa5x5-7-4-3.bin alias spa5x5-7-4-3.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7921/APPS-1.3.3.SBN alias APPS-1.3.3.SBN
tftp-server flash:/phones/7921/CP7921G-1.3.3.LOADS alias CP7921G-1.3.3.LOADS
tftp-server flash:/phones/7921/GUI-1.3.3.SBN alias GUI-1.3.3.SBN
tftp-server flash:/phones/7921/MISC-1.3.3.SBN alias MISC-1.3.3.SBN
tftp-server flash:/phones/7921/SYS-1.3.3.SBN alias SYS-1.3.3.SBN
tftp-server flash:/phones/7921/TNUX-1.3.3.SBN alias TNUX-1.3.3.SBN
tftp-server flash:/phones/7921/WLAN-1.3.3.SBN alias WLAN-1.3.3.SBN
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 100 protocol ieee
bridge 100 route ip
voice-port 0/0/0
timeouts ringing infinity
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
compand-type a-law
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer voice 1 pots
service stcapp
port 0/0/0
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
destination-pattern 9T
direct-inward-dial
port 0/1/0
no sip-register
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message UC520
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.3
load 7960-7940 P00308010200
load 7970 SCCP70.8-5-3S
load 7971 SCCP70.8-5-3S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-3
load 501G spa5x5-7-4-3
load 502G spa5x5-7-4-3
load 504G spa5x5-7-4-3
load 508G spa5x5-7-4-3
load 509G spa5x5-7-4-3
time-zone 23
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$Sn99$xYBPXrWY.yALV3.iP66tR/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Mar 24 2010 20:57:31
ephone-template  15
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-dn  5  dual-line
number 301 no-reg primary
label 301
description PhoneA Analog
name PhoneA Analog
ephone-dn  6  dual-line
number 302 no-reg primary
label 302
description PhoneB Analog
name PhoneB Analog
ephone-dn  7  dual-line
number 303 no-reg primary
label 303
description PhoneC Analog
name PhoneC Analog
ephone-dn  8  dual-line
number 304 no-reg primary
label 304
description PhoneD Analog
name PhoneD Analog
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 201 no-reg primary
label 201
description 201
name 201
ephone-dn  11  dual-line
number 202 no-reg primary
label 202
description 202
name 202
ephone-dn  12  dual-line
number 203 no-reg primary
label 203
description 203
name 203
ephone-dn  13  dual-line
number 204 no-reg primary
label 204
description 204
name 204
ephone-dn  14  dual-line
number 205 no-reg primary
label 205
description 205
name 205
ephone-dn  15  dual-line
number 206 no-reg primary
label 206
description 206
name 206
ephone-dn  16  dual-line
number 207 no-reg primary
label 207
description 207
name 207
ephone-dn  17  dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn  18  dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn  19  dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone  1
device-security-mode none
mac-address B8FA.CD82.0000
max-calls-per-button 2
type anl
button  1:5
ephone  2
mac-address B8FA.CD82.0001
type anl
button  1:6
ephone  3
mac-address B8FA.CD82.0002
type anl
button  1:7
ephone  4
mac-address B8FA.CD82.0003
type anl
button  1:8
banner login  UC500 Base Config - Default 8.0.2
line con 0
password 7 014310555E0F56
login authentication local_authen
no modem enable
transport output telnet
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
password 7 12491346170F5C
transport input telnet ssh
transport output telnet ssh
line vty 5 100
password 7 15421D5D012E7B
scheduler allocate 4000 1000
scheduler interval 500
ntp master
end
Got it working after rebooting the UC, thanks for your help anyway.
Glad a reboot fixed it for you.  I am kind of surprised you had to do that unless it was still running the old IOS.  Let me know if the VPN acts up on you.
Hi Steven, the split tunnel config is working as it should, the XA2 IOS image was already running when I followed your CCA instructions, I think it started working for me after the reboot just beacuse I made some ACL (the split tunnel one) modifications via CLI previously, so the UC was under the running-config and not the startup one.
Anyway, the VPN is performing well and the split tunnel ACL is behaving as it should, thanks for your help again.
Scott Pettit
Level 9
Level 9
Sigh, looks as though this workaround doesn't work because now my "interesting" traffic works but it breaks all other traffic that isn't interesting.  I'm going to attempt reconfiguring as a dynmap instead
