Weird Problem on UC540 regarding Max-Ephones
shaugupt
I have a UC540 Test Setup. It has 5 IP Phones attached to it.
Max-Ephones is configured as 6.
But now, I am getting Registeration Reject Message.
Sample Debug Output:
%IPPHONE-6-REG_ALARM: 24: Name=SEP1C17D3371B7D Load= term11.default Last=Phone-Reg-RejSEP1C17D3371B7D: Registration failed. Max phone count reached
Now when I change the Max-Ephones to 40
(max available) and do a "write&reload"(necessary) phones get registered without a problem.
I have attached the running config (relevant sections) to this post.
Please note:
I had defined ephones 1,2,3,4,5
and ephone-dns: 1,2,3,4,5,6,7,8,9,10,11,12
max-ephones: 6 when error comes, 40 when no error
max ephone-dns : 12
ios image: uc500-advipservicesk9-mz.151-2.T4
software pack: UC540-8.2.0
UC500 Model: Cisco UC540W-FXO-K9
Please can someone help me with this. It has really screwed my basics. ;-)
Any explanation for this behaviour will be very welcome. I just hope its not an IOS bug.
Shaurya
David Trad
Hi Shaurya,
In theory you shouldn't be playing around with this, if you used CCA to configure this systems then this configuration would be attached to the licensing that is associated to the system, manually adjusting this setting can cause unwanted issue and also have indirect consequences... I am not sure what you are trying to achieve by adjusting this, can you maybe elaborate further as to what you are trying to achieve??
Also note that with the current software pack, the system will default to 24 users license if I am not mistaken (Cant remember what this has changed too) and that is what licensing information would be configured on the system.
Going over the defaulted amount without any L-UC-PRO-8U licenses and the associated files stored on the flash card will cause you many of grief, especially when lodging support request as you system will be well and truly out of scope and you have manually put your box in an unlicensed state.
I would highly recommend you change this back to default and then lets work on that which you are trying to achieve.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David,
Thanks for your reply. :-)
Just FYI though, this UC setup is just for internal testing. And in our case we are not using CCA.
That's why gotta play around doing manual configs similar to CME ones.
Great idea though, i will check around the licenses just to check if they are the culprits.
As far as I know, if you got 'n' phones. The "max-ephone >= n". Its got something to do with router resources I think.
And I have not actually tested with 40 phones to this UC500, but just changed max-ephone from 6 to 40, and it worked for the 5 phones.
Cheers,
Shaurya
I have attached a txt file showing UC540 console output.
Here I start with max-ephone 40(everything is fine).
Then go down to 10, 8, 6...(unregisteration starts)
I've done "show telephony-service licenses" along the way.
It definitely seems to be a license related issue.
Below is after i configure max-ephone to 7.
UC540_Clone#show telephony-service license
License Supported:
uc-user: Registered, In Use. Handle: 0xE9000003
Maximum User License: 30
CSL license count: 8
CSL Requested User License: 0
Used User License: 4
Available User License: 26
Max Configured User (ephone + pool): 8
temp_license_expired_event: 0
license_installed_event: 0
license_count_change_event: 0
eula_not_accepted: 0
license_check_approved: 35
license_check_denied: 2
Possible License Denial reason: No active license.
Some more helpful info---
License Info (with max-ephone 6):
show ephone summ:- Max 6, Registered 1, Unregistered 4, Deceased 0 High Water Mark 7, Sockets 51
UC540_Clone#sh license
Index 1 Feature: uc-user
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Count: 8/0/0  (Active/In-use/Violation)
        License Priority: Medium
UC540_Clone#
show platform software license
License UDI                  : UC540W-FXO-K9:FHK144077QZ
Maximum User Licenses        : 30
Used User Licenses           : 1
Available User Licenses      : 29
Base License                 : 24
CSL Base License             : 8
Max number of upgrade PAK allowed: 1
License Supported:
uc-user: Registered, In Use. Handle: 0x44000003
Used User License: 1
Available User License: 29
license_check_approved: 5
license_check_denied: 111
