where is my Paging server ?
sapeter
i got my BE6k roughly a month ago. Did the CUCM and IM&P install. No problem.
Wanted to install the Paging server, but do't know HOW TO DO IT ?
in the vmware datastore, there is the Informacast ISO, but when you add this ISO to be used during a new VM bootup, it fails.
This ISO does not seem to be bootable. I have no idea how to proceed and install the Paging sever.
Also, in all the documentation it says, that ESXI comes LICENCED. Not true (at least in my case). I had to dig my paper envelopes, and manually type-in the master serial number. (hadn't i done so, i would be in the standard 60 day ESXI demo mode...)
nmanglik
The Paging Server .ISO is not a bootable file and contains .OVA and user guides. Please open the .ISO to get the .OVA file. Deploy Paging Server .OVA, like you would have with other applications and then power on the virtual machine.
Instructions to deploy and install BE6000 applications are provided:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/BE6000/InstallationGuide/9_x/CUCM_BK_IA4BAD3A_00_installing-cisco-business-edition-6000.html
Nitin.
nmanglik
Nitin.
