01-18-2011 08:52 PM - edited 03-21-2019 03:32 AM
I have created a blast group with several users, forwarded to VM after a certain amount of rings, however I cannot figure out how to give access to teh VM box. Would someone be able to shed light onto this? I am able to get to the pin prompt bu using teh blast group extension however the default password is not working nor do I see where to change it, I can only change it for users using CCA 3.
Thanks!
John
Solved! Go to Solution.
01-19-2011 02:49 AM
Sure thing. The members of the hunt group's general delivery mailboxes access the GDM by logging into their own personal mailbox, and then use option '9' to access the GDM to record custom greetings and to retrieve voicemails.
Steve DiStefano
01-19-2011 02:49 AM
Steve DiStefano
02-21-2011 05:09 PM
I have configurated a hunt group's general delivery mailboxes, all user members of this hunt group can have access to the mailboxe using the user login and option 9. But the hunt group have 9 messages not readable from mailboxes access.
Have you already have this bug ?
Sébastien DOS-SANTOS
