Change incoming call routing depending on schedule
sethschmautz
Level 3
Level 3
Has anybody had any luck changing call routing dependant upon the time that the call comes in?  I like the ability to change the AA message according to the schedule, but would also like to change the incoming call routing as follows:
Normal Business day:
Incoming call --> Blast Group 1 --> Blast Group 2 --> AA
After hours/weekends/holidays:
Incoming call --> AA
We would like to be able to continue to have a real person answer the phones during the business day, but after hours route all calls directly to the AA without going through the two Blast Groups.  Thanks in advance.
Seth
Steven Smith
Level 7
Level 7
Here are some options.
https://www.myciscocommunity.com/docs/DOC-1419
You could have the call flow be...
Inbound Call -> Ephone-dn CFB/NA -> Blast Group 1 -> Blast Group 2
Inbound Call -> Ephone-dn Night Service -> AA
5 Replies 5
Steven DiStefano
Have you tried this.  The new CCA 2.0 that has since came out is even more powerful, but this summarizes well I think...let us know.
https://supportforums.cisco.com/docs/DOC-9525
Eivind Jonassen
Level 4
Level 4
Seth,
Have you tried the CUE editor???
What you have do is make a custom AA script with the following flow
Incoming call -> AA -> business  open -> redirect the call to Blast group 1
                              -> business closed -> play a custom WAV file
I can post a simple script for you if you like? You can then upload it through the WEB interface
Eivind
Steven Smith
Level 7
Level 7
sethschmautz
Level 3
Level 3
Hey guys,
Thanks for the help.  My UC520 took a turn for the worse, so as soon as I have that squared away with the TAC, I'll get back on this.  The script editor looks very powerful and a bit daunting.  I'll be able to dig into it a little more shortly.  Thanks for your help, I'll be sure to update this question when I have it resolved.
Seth
sethschmautz
Level 3
Level 3
I ended up creating an incoming extension that all calls were routed to. That extension is setup to always forward all calls to our first Blast Group during the day, and to the AA after hours (using night service). Thanks for the help.
