08-25-2010 01:42 PM - edited 03-21-2019 02:55 AM
Two questions regarding multi-site setup-
1. Is there a limit on the number of UC5x0s you can have at different sites?
2. Can you mix UC520, 540 and 560s at different sites and have them work together?
3. Is there a limit of how many SR routers that can connect to each UC5x0?
Thanks!
Solved! Go to Solution.
08-25-2010 02:49 PM
This question in asnwered in CCA Q&A doc: http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps7256/ps7287/prod_qas0900aecd806b8e39.html
• Up to five Cisco Unified Communications 500 Series
• Combination of up to five Cisco 500 Series Secure Routers and Cisco Small Business Pro SA 500 Series Security Appliances
• Up to 10 Cisco Small Business Pro ESW 500 Series Switches
• Up to 10 Cisco Small Business Pro AP 500 Series Wireless Access Points
• There is no restriction on the number of supported endpoints (IP Phones, Video Surveillance Cameras, printers, and so on)
So, to address your questions:
Anna
08-25-2010 02:49 PM
Anna
08-26-2010 06:38 AM
Thank you!
Is that limit set by CCA or the device itself?
In another words, if I was to use all 520s and using CLIs to configure only, can I go over the limit of 5?
08-26-2010 04:00 PM
The device limit I mentioned is based on what Small Business Team has defined as the "small business network deployment" and what was tested. CCA does not have a hard limit, but going above what we specified was not tested by the team.
Anna
